Find the module lock, highlighted in green in the picture above. Lift this lock and the module will disengage from the main body. If the lock seems to be frozen, use the provided Allen key #1 to lift it, or move the entire unit to a warmer ...
Please refer to the troubleshooting guide below when encountering any issues Please refer to the guidance The Yarbo Tool for fixing the internet connection
Store your Snow Blower in the garage or a sheltered area to keep your Yarbo safe. Remove the rear cover, press the power button to turn off Yarbo(IMPORTANT!). Remove this cover from Snow Blower module, with Allen Key #1. Screw the connector onto the ...
Please refer to this article for assistance in case your Rover Hotspot not being detected on your mobile device, there are steps you can take to troubleshoot and resolve the issue. This guide will walk you through the process, and you can use the ...
