【Troubleshooting】Rover Hotspot is Not Detected on Mobile Device
Please refer to this article for assistance in case your Rover Hotspot not being detected on your mobile device, there are steps you can take to troubleshoot and resolve the issue. This guide will walk you through the process, and you can use the Yarbo Tool to assist in fixing the Wi-Fi connection problem.
Step 1: Check Physical Connections
Before diving into software solutions, ensure that the physical connections are secure. Follow these steps:
  1. Confirm that the Rover Hotspot is powered on and properly connected.
  2. Verify that the Wi-Fi signal on the Rover Hotspot is active.
Step 2: Restart Your Devices
Sometimes, a simple restart can resolve connectivity issues. Follow these steps:
  1. Turn off your mobile device and restart your Yarbo device.
  2. Wait for a few seconds and then turn them back on.
  3. Attempt to connect your mobile device to Yarbo's Rover Hotspot again.
Step 3: If the Rover Hotspot is still unable to find in your mobile device, please Use the Yarbo Tool
The Yarbo Tool is designed to assist in troubleshooting Wi-Fi connection issues. Follow these steps:
  1. Download and install the Yarbo Tool on your laptop.
  2. Open the Yarbo Tool and navigate to the Wi-Fi Channel function in the Rover section.
Please refer to the article How to Fix the Internet Connection with Yarbo Tool?to follow the step by step guide to effectively address Wi-Fi connection issues with your Rover Hotspot.
Step 5: Contact Support
If the issue persists, please reach out to Yarbo support for assistance. Provide details about the problem and steps you've taken so far.
    • 【Troubleshooting】How to Fix Wi-Fi Channel Issue?
      Please kindly refer to the content below for your reference if the Yarbo rover cannot be detected on your mobile device due to the Wi-Fi channel issue. Switch the Wi-Fi Channel with Yarbo Tool Step 1: Download and install the latest version of the ...
    • 【Troubleshooting】What Should I Do if my RTK Base Flashes Green Light All the Time?
    • How to troubleshoot connectivity issues between the app and the mower?
      The APP Controls the Machine and often Disconnects Contact Support. Please reach out to Yarbo support for assistance. Provide SN code and stay connected, further diagnosis and confirmation of the problem will be conducted. Hotspot Issues ① Rover ...
    • [2023] Modes of Network Configuration
      Hotspot Mode Tips: For optimal mapping performance, we recommend utilizing Hotspot Mode to ensure a prompt response without any delays. When operating in Hotspot Mode, please ensure you stay within a 10ft range of Yarbo. Upon completing the mapping ...
    • Troubleshooting Guide for Yarbo
      Please refer to the troubleshooting guide below when encountering any issues Please refer to the guidance The Yarbo Tool for fixing the internet connection
