Installation Necessity and Cable Protection: Securing the Cable Ramp is crucial to safeguard the Power Cable. When users install the Docking Station close to a wall, a weak GPS signal may occur, causing Yarbo to veer away from the Docking Station. ...
DO NOT change the location of the RTK or the Docking Station. Any change in location requires a full data reset, reinstalling the docking station and re-mapping from scratch to guarantee precise positioning.
Before installing the docking station, it is important to make the necessary preparations: Concrete & Brick Ground Grass Ground Impact Drill + Expansion Bolts Steel Nails or Grass Pegs Next, to ensure optimal functioning of your Yarbo, follow these ...
Once your docking station and RTK antenna are set up, we advise not moving them. But if you need to relocate them, make sure to follow the instructions for "Reinstall the docking station" and "Reinstall the RTK" in the app. This is important because ...
Open your Yarbo application and locate the settings icon. Scroll through the options until you find "Find my Yarbo" and select it. Upon selection, satellite imagery will be displayed showing the precise locations of your Yarbo, the RTK Base Station, ...
