How to handle and store battery safely?
Where to store
The ambient temperature and humidity of the stored products shall meet the conditions specified in the form below, and shall be placed in a clean, day, ventilated room with moisture-proof, dust-proof, shock-proof and anticorrosive measures.
| Storage Temperature | ≤1 month | -20℃~60℃ |
| ≤3 month | -20℃~45℃ |
| ≤1 yaer | -20℃~20℃ |
| Storage Humidity | 0~70% RH
How to store
- Avoid contact with substances and keep away from fire and heat sources.
- The batteries should be stored at room temperature, charged to about 30% to 60% of capacity. In case of over-discharge, batteries should be charged to a suitable range (30% to 60% of capacity) for one time every 3 months while storing and batteries should be charged to 100%, then completely deplete it for one time after being stored more than one year in order to activate it and restore energy, and then maintain the battery level between 30% and 60%.
- Avoid storing batteries that are fully discharged or fully charged for extended periods.
- Store batteries separately to avoid them touching each other.
Safety tips for charging and maintaining the mower's battery
The battery is a crucial component of the Yarbo, and its condition directly affects the operational efficiency and safety of the device. By following proper charging and maintenance practices, you can effectively extend the battery's lifespan, ensure ...
Keep Battery Pack Healthy
DO NOT leave the battery pack inactive for more than 3 months. Leaving the battery pack inactive for an extended period will significantly reduce its performance and cause fast degradation. DO charge the battery pack for 15 minutes at least once per ...
How to properly store the mower during off-seasons or periods of non-use?
Turn off your Yarbo: Before detach the mower module, please turn off your Yarbo to ensure safety, as well as to protect the machine. Detach and Clean the Mower Module: Detach the lawn mower from the universal body, thoroughly cleaning the underside ...
【Must Read】Safety Guidelines about Yarbo
Product Usage For the safety of yourself and your property during product usage, please adhere to the following guidelines: WARNING: Keep Away from Children: Never allow children to operate the product. Adult Supervision: Only let adults operate the ...
【Must Read】How to use the Plow Blade safely?
For your safety and to safeguard your property during product usage, please adhere to the following guidelines: Installation and Inspection: Before attaching the plow blade accessory to the auger housing, ensure that the Yarbo is powered off and ...
