What Is “Mapping” in the Yarbo App? – Work Areas, Pathways & Zones
[2024]What is "Mapping"
Mapping Work Area
  1. Click the Create A Map button at the bottom of the interface.
  2. First, turn Yarbo back to the docking station and click the start button.
  3. Click to draw work area's boundaries.
  4. Then please manually drive Yarbo to the perimeter of the work area, click Start to map that area.
  5. Utilize the virtual controller to control the yarbo and outline the boundary of the work area. (Just draw the boundary of the lawn area).
Mapping Pathway
  1. Click the Enter My Yard button at the bottom of the interface.
  2. Click the Edit Map button to enter the modification page.
  3. Click the Create button and choose to create a pathway
  4. Click the Start button to initiate the drawing process for the pathway, work area or the process is finished, click the Next button.
Deleting Work Area
To delete a working map, simply click on edit map and then click on that Work Area that needs to be deleted and a row of options will appear at the bottom containing delete, edit, rename, throwing and setting.
Creating a No-go Zone
No-go zone should be considered when there is area that does not require mowing or is dangerous for Yarbo to go in the work area. If you do not understand what the No-go Zone is, please refer to section 4.1 in the user manual.
  1. Click the Edit Map button to enter the modification page.
  2. Clicking on the Create button will give you the option to create a No-go Zone.
  3. Click the add icon to draw the No-Go Zone.
  4. Click the Start button and use the virtual controller to guide the yarbo and outline the boundary No-Go Zone.
  5. Click the Finished button once you have finished outlining the No-Go Zone.
Creating a Sidewalk
Sidewalk mode allows yarbo to pass through narrower areas and can act as a partial pathway.
  2. Clicking on the Create button will give you the option to create a Sidewalk.
  3. Click the Start button to draw a sidewalk using the virtual controller to control the Yarbo.
  4. Click the Done Button once you have finished outlining the Sidewalk.
    • [2024] What is "Pathway,Working Area and Sidewalk"
      In the Yarbo app, there are three key types of working areas that help Yarbo operate efficiently: Pathway, Working Area, and Sidewalk. Each area serves a specific purpose to guide Yarbo's tasks effectively. Here’s an overview of each type: Pathway ...
    • [2024] How to use no-go zone template?
      Create No-Go Zone Template Open the Yarbo App and tap Enter My Yard on the home screen. Tap the Edit Map icon in the top‑right corner to switch into map‑editing mode. Edit Map Tap the Create button at the bottom of the screen. Create From the list, ...
    • [2024] When Do You Need to Draw a No-Go Zone?
      When Do You Need to Draw a No-Go Zone? The No-Go Zone refers to enclosed areas within Yarbo’s working area where you do not want it to enter. While Yarbo’s stereo depth perception allows it to recognize and avoid many obstacles automatically, certain ...
    • [2024] What is No-Vision Zone?
      What Is a No-Vision Zone? As the name suggests, a No-Vision Zone is an area where the camera-based obstacle detection is disabled. This means that within this zone, your Yarbo lawn mower will not use its cameras to detect or bypass obstacles. When ...
    • [2024] Why is your work plan not working?
      Docking Station and Pathway Setup When creating your work plan, it is essential to first ensure that the docking station is properly set up. Once the docking station is in place, you must draw a pathway that connects it to your designated work area. ...
